Activity Forums Apple Final Cut Pro Problem Backing Up Events Onto Another Drive
  • Problem Backing Up Events Onto Another Drive
    Posted by Lucky Haskins on February 22, 2012 at 12:48 am
    Hey Kids…
    I have just started making the transition to FCP X and have run across an interesting issue. I have always (with FCP7) backed up my project drive every night onto my trusty Drobo. No problems…always protected if my project drive threw a rod.
    I have done the same thing with FCP X and something is throwing me. I have 4 events in the project I am working on right now. Last night I backed the whole project drive up (and the drive has my 4 events on it). I checked the Drobo this morning and of course there were the contents of my project drive (including the 4 events). Cool.
    BUT…when I fired up FCP X I got a warning message about a conflict and when I checked OK two of the events were recognized by FCP X on the project drive but FCP recognized the other two events on the Drobo…so it split up the events across two drives when in fact all four events were on the Project drive as well as the Drobo.
    Does having back ups of the events confuse FCP X and make it start randomly recognizing events. Obviously I only want to be working on events in my project drive not the backed up versions on the Drobo. Am I missing a key fact when trying to back up my events (and projects for that matter) and creating some sort of parallel universe that baffles FCPX?
    The crucial question…how do I best back up/protect my events and/or projects on a daily basis?
    Thanks.
    Jeremy Garchow replied 14 years, 7 months ago 3 Members · 4 Replies
  • Loren Risker
    February 22, 2012 at 1:33 am
    I just put my event backups in a folder called fcpxbackups so FCPX doesn’t find them.
  • Jeremy Garchow
    February 22, 2012 at 1:36 am
    [Lucky Haskins] “The crucial question…how do I best back up/protect my events and/or projects on a daily basis?”
    On the drobo, set the backup to go to a folder that is not Root level > Final Cut Events or Final Cut Projects.
    Make a folder named Backups or something and have them go in there.
    Quit FCPX before moving anything on your drobo now.
    Jeremy
  • Lucky Haskins
    February 22, 2012 at 2:43 pm
    Thanks guys…seems kind of silly that you have to trick FCPX but whatever works, right?
  • Jeremy Garchow
    February 22, 2012 at 4:59 pm
    [Lucky Haskins] “Thanks guys…seems kind of silly that you have to trick FCPX but whatever works, right?”
    We have to remember that FCPX is a database, and it tags each piece of footage with a Unique ID, and the Events/Projects are databases that track the relationship of those clips to all of the data and time information that goes with it.
    So, when FCPX sees two of the exact same things, it picks one, otherwise it would have to track two different databases and update both of them at the exact same time with completely accuracy.
    It would be similar to trying to a budget in Excel with two separate spreadsheets, modifying one, and updating the other all in real time.
    I’m sure it’s possible, but unnecessary.
    Backups should be just that, backups, not working copies of current elements.
    2 pennies.
    Jeremy
