Activity › Forums › Adobe After Effects › Problem animating paths from Illustrator
  • Problem animating paths from Illustrator
    Posted by Damian Riddell on December 20, 2011 at 8:51 pm
    I need some text to animate from a thin script font to another heavier script font, but the words stay the same. I built out my starting font & ending layout in AI and converted the text to paths. For each character I copied path data from AI to a solid in AE, but on playback the vertices will animate in the wrong direction, essentially flipping each path. I’ve posted an image below.
    -I have ‘set the first vertex’ for both the starting & ending keyframes
    -I have tried ‘setting the first vertex’ on a different position on the path
    -I have attempted to reverse path in AI
    -I have tried mask interpolation, including all 3 of the matching methods, ‘use 1:1 vertex matches’, & ‘first vertex match’
    -I thought that maybe the shapes were too complex and broke each character down into multiple basic shapes. I’ve posted an example of one below
    -I made sure each character had the same number of vertices
    What am i doing wrong here? Is there a way to map vertices beyond it’s first? Or somehow reverse the order? The reverse order button in illustrator does not seem to translate into AE. I am running CS5. Thanks in advance for any help.
    Damian Riddell replied 14 years, 9 months ago 40,903 Members · 1 Reply
  • Damian Riddell
    December 21, 2011 at 12:43 am
    Ok, follow up: the Vertex order was reversed between the masks and AE doesn’t seem to read AI’s reverse order button. I found a script that will reverse the order:
    https://aescripts.com/reversemaskpath/
    Works like a charm now.
