Activity Forums Apple Final Cut Pro Legacy Problem adding transitions
  • Problem adding transitions
    Posted by King Law on July 1, 2011 at 2:07 am
    I managed to capture all the video I needed from my canon xha1,I also managed to apply transitions to almost
    Every part of the project as needed tested them and they work fine, accept for the last 3 clips in the timeline.
    Whenever I try to add a transition between 2clips the transition stays on one of the clips instead of bridging the two clips as usual what am I doing wrong here.help
    I have a Mac pro intel 3.0 ghz,
    8 gigs ram,
    Radeon 1900xt video card
    Jeff Greenberg replied 15 years, 2 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    July 1, 2011 at 11:46 am
    King,
    A transition requires footage from past the edge of the clip. If you use the last frame of a clip, the transition cannot extend beyond that point – as there is no material to draw from. The concept is called a ‘handle’ – the unused footage.
    There are a couple of ways to deal with this. IF you use the blade tool and cut 15 frames off the ends (shortening both clips) you’ll be able to create a transition.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
