Activity › Forums › Apple Final Cut Pro Legacy › Problem adding transitions need help!!!
  • Problem adding transitions need help!!!
    Posted by King Law on July 1, 2011 at 1:43 am
    I short a music concert with my canon xha1 managed to capture every clip I needed I added transitions to almost every clip like I wanted except the last 3 clips whenever I drop a transition in between the 2 clips it stays on top of either the clip on the left or the one on the right. How do I get it right what I’m I doing wrong. I have a Mac pro 3.0 ghz intel,8gigs of ram, radeon1900xt video card
    Sean Simms replied 15 years, 3 months ago 3 Members · 2 Replies
  • Brendan Maghran
    July 1, 2011 at 7:26 am
    Is there enough room on the heads and tails of the clips for this transition? You need to have a few frames on either side for the transition to occur.
  • Sean Simms
    July 2, 2011 at 4:25 am
    Maybe you are at the end or beginning of those clips and there is no room to do some transitions like cross-dissolve…etc.
