Activity Forums Adobe After Effects problem adding output modules to AE
  • problem adding output modules to AE
    Posted by Neil Harris on August 3, 2006 at 4:34 pm
    I’m trying to create a series of output modules that will crop a long horizontal comp (720×2880) into 720 x 576 portions to lay off onto a digi. I’m cropping each individual module using the top and bottom parameters. The problem is that AE cannot seem to handle the ‘crop’ numbers after about 1500 and when i apply the module and check the figures they have disappeared.
    Anyone experienced this before or know a fix.
    Ultimately I can output this in a different but this way seems the neatest and quickest.
    Neil
    Tim Kurkoski replied 20 years, 1 month ago 2 Members · 1 Reply
  • Tim Kurkoski
    August 3, 2006 at 6:41 pm
    What version of AE are you using?
    I would just set up several pre-comps and adjust the source comp as necessary for each section.
