Activity Forums Adobe Premiere Pro Problem 100% CPU use – Premiere CC 2015 – LGA 2011
  • Problem 100% CPU use – Premiere CC 2015 – LGA 2011
    Posted by Piotr Abramowski on February 12, 2016 at 6:06 pm
    I have Adobe Premiere CC 2015, 5960X, Geforce GTX 970 OC, 32GB DDR4, 2x disk SSD… and I have a big problem my CPU usage for Adobe Premiere CC.
    During EXPORT my film – my CPU only uses 35-55% at speeds 2,40GhZ etc…. What to do to take advantage of the full power of the CPU?
    I will add – I have the same EXPORT Premiere and the same EXPORT Media Encoder.
    Please Help ME 🙂
    THX!
    Torsten Gruenwald replied 10 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Torsten Gruenwald
    February 16, 2016 at 9:18 am
    is ok!
    I had ask an adobe worker…
    when you using GTX and the card is active in your project, then Premiere and your system using CPU and GTX together, and some effects are rendering only with the CPU, some other are rendered by the GTX. It depends on your footage and your export settings ( MP4 or mpg) for rendering.too.
    and check the preference for your project and premiere. is there GTX active?
    have a look
    https://greenwoodworx-media.blogspot.de/2012/01/performence-und-stabilitat-adobe.html
    http://www.greenwoodworx.com
    video-production and media-productions, Berlin
  • Torsten Gruenwald
    February 16, 2016 at 9:32 am
    update to test
    what if, when you export an original footage with the same settings? maybe then you will have 100% CPU!!!
    when you put some effects on the sequence, then the GPU will render the stuff to export/media encoder
  • Piotr Abramowski
    February 16, 2016 at 10:53 am
    Hi – very! very! THX!!!!!!!
    I understand NOW! Must buy other weaker GPU 🙂 haha!
    but honestly – would be good to utilize the full power of the PC
    100% CPU AND 100% GPU 🙂
    THX, Robert 😉
  • Tero Ahlfors
    February 16, 2016 at 11:13 am
    Not every format/effect/thing you export requires 100 percent of the computer.
  • Torsten Gruenwald
    February 16, 2016 at 11:36 am
    maybe…
    what about your energy setting in your OS?
    switch on high…
  • Martin Parki
    March 1, 2016 at 12:01 am
    Hi Piotr. Would you be so kind to tell me if I can enable this graphic card GeForce GTX 970 in Premiere Pro CC 2014 for mercury playback engine?
  • Ant Gonzalez
    March 3, 2016 at 2:07 am
    I’m using the latest Premiere (9.2) in Windows 10 on a 2011-3 chip with a 980 ti. I noticed the other day that exporting a sequence using the DNxHD codec was only using 53%-74% CPU usage. Exporting the same sequence using the ProRes codec utilized 99%-100% the whole export. I think the CPU usage may depend on the codec you’re using. I’m curious now and will run some benchmarks to see the results across different commonly used codecs.
  • Torsten Gruenwald
    March 10, 2016 at 11:56 am
    Martin, to enable your not certified cuda Card, is here to read and done, go thru .
    you have to add an txt file, as an admistrator…
    https://www.studio1productions.com/Articles/PremiereCS5.htm
