Probelm when importing quicktime clips and general error message
Hi, I’m new to this forums. I have two problems that are driving me crazy.
I’m doing an internship from home with Univision, and one of the producers sent me an external hard drive with tons of content for me to edit and play with. The hard drive is a Lacie d2 quadra connected to my Imac through Fiewire800 port. I have a new 27 inch Imac with Final Cut Pro 7 installed.
Now I read that the clip settings have to match the sequence settings and I’ve been trying to do that but it’s not working.
For example, here are some of the clips settings:
frame size: 720 x 480
vid rate: 29.97pfs
Pixel Aspect NTSC-CCIR 601
Compressor H.264
Audio 48.0 HKzHow can I match that to the sequence settings? I keep getting a red line on the timeline which means I have to render all the time? Anyone please help 🙁
I’m getting another error, anytime I import some clips and try to play them on the viewer window I get “general error” message. All the clips play fine in quicktime
