Activity Forums Adobe After Effects Probably quite a common problem…
  • Probably quite a common problem…
    Posted by Luke Hale on May 9, 2007 at 12:42 am
    I rendered out a movie, 800*600, and when i play it back in quicktime the frames freeze and the frame rate drops to about 0.5/s. The movie does seem especially large, 450MB for 15 seconds. The original project was quite a heavy render, with many thousands of particles in Trapcode Particular. Is there anyway of making it playback normally without freezing? Or re-rendering to make sure it plays normally? I currently have 2GB RAM and cannot add any more. I suppose this is a common problem?
    Thanks a lot for any help, it is greatly appreciated.
    Martin Løland replied 19 years, 4 months ago 3 Members · 3 Replies
  • Darby Edelen
    May 9, 2007 at 3:22 am
    If you rendered out of AE losslessly then the data rate of the video is probably too high for your computer to handle. If you have QuickTime Pro (and you should) you can just (cmd-e/ctrl-e) export out from QuickTime player to a new codec, I recommend Photo JPEG for good quality and fast playback (still large file size though).
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Luke Hale
    May 9, 2007 at 10:19 am
    Great, thanks a lot. What codec settings could i use on my original render to ensure this doesn’t happen?
  • Martin Løland
    May 9, 2007 at 11:19 am
    If your final export is a video you just want to see, I suggest you export it in .avi with xvid compression.
    You can use VirtualDub and the xvid codec to do this.
    Martin Studios
