Activity › Forums › Storage & Archiving › Proavio EB8MS questions
  • Proavio EB8MS questions
    Posted by Laco Gaal on August 5, 2013 at 9:59 am
    Hi there,
    could anyone point me to a HDD compatibility list for this enclosure? (Proavio site doesn’t offer one…)
    If there’s anyone who use this enclosure, what kind of speeds should I get with a good controller card?
    Laco
    Jon Schilling replied 13 years, 1 month ago 3 Members · 13 Replies
  • 13 Replies
  • Jon Schilling
    August 5, 2013 at 3:07 pm
    Laco,
    It’s there, see this page: https://www.proavio.com/index.php/support/support-resources/downloads/summary/38-compatibility-lists/22-general-compatibility-list
    From main Proavio page: http://www.proavio.com > Support > Downloads > Compatibility Lists > General Compatibility List (once you’ve got that page up, SCROLL DOWN to EditBOX) which is the EB8MS (8 bay) series as well as the EB4MS (4 bay)….
    Jonathan Schilling
    Vertical Sales Manager
    Proavio Storage by Enhance Technology Inc.
    12221 Florence Ave.
    Santa Fe Springs, CA 90670
    Dir: 562-777-3498
    Main: 562-777-3488 X106
    Fax: 562-777-3499
    Email: jon@proavio.com
  • Laco Gaal
    August 5, 2013 at 3:08 pm
    Thanks, but the EB8MS isn’t on the page. Is it the same as for the EB800MS?
  • Jon Schilling
    August 5, 2013 at 3:11 pm
    Laco,
    Scroll down to “EditBOX” (which encompasses the EB8MS) the EB800MS has a 6G backplane while the EB8MS has a 3G backplane, they are different products with different drive requirements.
    We suggest running the Areca 1223X with the EB8MS which will give you performance of 900MB/s read-write….
    Should you need anything else, feel free to post on this forum or contact me directly, we’re here to help.
    Jonathan Schilling
    12221 Florence Ave.
    Dir: 562-777-3498
    Fax: 562-777-3499
  • Laco Gaal
    August 8, 2013 at 11:53 am
    Jon,
    thanks for your help, you’re very kind!
    As 4TB hard drives are much more expensive, I’ll go with the 3TB ones. Would you recommend the Toshiba DT01ACA300?
    Also I bought the Proavio as a used enclosure, so the RAID controller was given with it. It is an Areca 1680X, hope to get speeds like you mentioned:)
    Later, I would like to buy one of your 16bay, 4K capable enclosures…
  • Bob Zelin
    August 8, 2013 at 12:35 pm
    the Areca 1680 is a 3g enclosure. You will not get the speeds you expect. You will get 600 MB/sec at best. You need a 6g controller like the new Areca 1882x to achieve these faster speeds. And if your enclosure is an older 3g enclosure, even with an 1882x, you will still only get the slower speeds.
    Since you are looking to save money, and you have a used RAID enclosure, and a used Areca 1680, just get any drives – the Toshiba’s will be fine for what you are doing. You are not building a state of the art system – you have limited funds, and you are doing the best you can with the limited money that you have available.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Laco Gaal
    August 8, 2013 at 12:46 pm
    Thanks Bob,
    I was looking to buy a 6G enclosure, with the Areca 1882x as you advised before in this forum.
    But a very good opportunity came for me to buy a 3G enclosure, and a 3G card together at the fraction of the price…
    As the most demanding thing for me right now is 2K DPX, 5-600MB/s is better than enough:)
    But I understand that this is not a state of the art system.
  • Laco Gaal
    August 8, 2013 at 2:28 pm
    The Toshiba drive is on the compatibility list! Is just wanted to make sure that I choose the right one from the list.
  • Jon Schilling
    August 8, 2013 at 2:48 pm
    Laco,
    The drives you want to use:
    3TB
    Toshiba
    DT01ACA300
    SATAIII / 6Gb
    64MB
    7200
    3.5
    Are on the compatibility list, they’ll work fine!
    Jonathan Schilling
    12221 Florence Ave.
    Dir: 562-777-3498
    Fax: 562-777-3499
  • Laco Gaal
    August 8, 2013 at 3:28 pm
    thanks, as soon as I receive my Proavio Enclosure I’ll order the drives!:)
    Have a great weekend Jon!
  • Jon Schilling
    August 8, 2013 at 3:33 pm
    Laco,
    Glad to help, feel free to contact me if you need anything else.
    Jon
    Jonathan Schilling
    12221 Florence Ave.
    Dir: 562-777-3498
    Fax: 562-777-3499
