Activity › Forums › Storage & Archiving › Proavio boxes and raid card
  • Proavio boxes and raid card
    Posted by Paul Toth on April 15, 2011 at 4:44 pm
    So I have two Proavio boxes, 1 is a 10 drive SATA with eSATA out (x2) and the other is identical except it is only 8 drives. The 10 drive unit has 10x 1TB drives and the 8 drive has 8x 500GB drives.
    Currently I am running them as a RAID 5/0 using the highpoint 2314 card but the performance seems so sluggish and stuttery…
    My computer is a dual Xeon Dell with 24 GB ram so it is plenty fast enough and I’m running Win 7 64 bit. Editing with CS5 and a 4800 nVidia card.
    My question is how to configure the drives to perform better. I have seen indications that the highpoint cards are not the best bet so any recommendations and ideas would be welcome.
    Jon Schilling replied 15 years, 5 months ago 3 Members · 4 Replies
  • Alex Gerulaitis
    April 15, 2011 at 7:44 pm
    Unfortunately there aren’t too many high performance RAID cards with eSATA port-multipliers – the interface is too limiting. In other words, to get significantly better performance, you’d need to change the controller and the boxes.
    Most people end up with MiniSAS for direct-attached storage if the number of drives is 8 or more.
    8-bay boxes start at about $600; 16-bay – $2K. A decent controller – $700-900 (Area, ATTO, LSI).
    Alex (DV411)
  • Paul Toth
    April 15, 2011 at 8:59 pm
    Thanks Alex… so in changing out the boxes can I use the existing SATA drives? Do you have any recommendations on boxes?
  • Alex Gerulaitis
    April 15, 2011 at 9:11 pm
    Yes you can re-use your SATA drives; the data on them is unlikely to migrate to the new setup intact – so if you have anything critical on them, back it up.
    You’ve got a total of 18 drives, correct? 10x 1TB, 8x500GB? Would you be open to getting one 24-bay enclosure for all of them, or would you prefer to get two – an 8-bay and a 12- or a 16-bay?
    I’ve had great results with iStoragePro (division of Ci Design) boxes in terms of quality and support – and also was impressed by Stardom SohoTank. Will be happy to do a quote for you once we zero in on a configuration.
    Alex (DV411)
  • Jon Schilling
    April 18, 2011 at 11:34 pm
    The Stardom SOHOTANK (8 bay) ST8-U5 features a 6Gb/s backplane, we’re getting sustained read/write performance of 830+ MB/s in RAID 6 with the ATTO R680 6Gb/s card with SATA drives & DV411 would be the place to buy.
    Jon Schilling
    Stardom Storage
    https://www.stardom-usa.com
