Activity Forums Apple OS X ProApps Codec 1.0.5 keeps appearing in Software update, after install
  • ProApps Codec 1.0.5 keeps appearing in Software update, after install
    Posted by Niklas Wikman on September 29, 2014 at 4:42 pm
    Software update regularly prompts me to install ProApps codecs 1.0.5 – I have repaired disk permissions, etc.
    Not sure why it keeps popping up. Anyone had found a solution to this?
    I’m on Lion 10.7, FCP 7.0.3, DVDSP 4.1, Compressor 3.5, etc.
    Niklas Wikman replied 11 years, 10 months ago 2 Members · 4 Replies
  • Jared Smith
    November 16, 2014 at 4:45 am
    I’m having the same issue… can’t update itunes without getting this update done
  • Niklas Wikman
    November 16, 2014 at 10:02 am
    I found the software Manifest and used that to manually copy the codecs into the right place.
    Then my Macs stopped prompting for the update.
  • Jared Smith
    November 16, 2014 at 4:29 pm
    I have no idea how to do that… could you walk me thru that process if you don’t mind
  • Niklas Wikman
    November 17, 2014 at 11:10 am
    Hi Jared,
    First, download the Pacifist application from https://www.charlessoft.com/
    (It’s free, but you can donate if you wish).
    Install Pacifist and drop the ProApps 1.0.5 DMG file onto Pacifist
    You will now see the content of the installer.
    What happened to me was that one or two of the codecs files was not installed/copied into the right directory (I think that one of the supposed directories did not even exisst).
    I suggest that you let Pacifist install/copy all the files in the .dmg file to your computer. Then it should work just fine.
