Activity Forums Zaxwerks ProAnimator won’t recognized my PSD files
  • ProAnimator won’t recognized my PSD files
    Posted by Zeno Pierre on May 1, 2009 at 2:20 am
    Hi, All
    I hare used ProAnimaor on several occasions and have had great responses from it.
    But, this time, when I was trying to use it today, it won’t recognize any of my Photoshop images. I’m trying to past a photo shop photo onto a vector shape also created in Photoshop but when I go to the retrieve the PSD file, the PSD file remains grayed out.
    I was thinking that I needed to go back to Photoshop and recreate the PSD file to make sure that I saved it correctly but, then again, I’ve found that all of my previously created PSD files are now also grey out and I can’t select any of them!
    What in the world did I do wrong?
    Help!
    Edward Wu replied 17 years, 4 months ago 2 Members · 1 Reply
  • Edward Wu
    May 1, 2009 at 11:23 pm
    Hi Zeno,
    If you are working with ProAnimator on Windows, one of the things that happens is when you are opening a texture map, it will ask for the file type that you want to open. Make sure to choose that you want to open a Photoshop file, and you should be able to select the Photoshop file. It’s possible that your last texture map selection was a “jpeg” so it is still looking for “jpeg” files to open.
    Hope this helps.
    Best,
    Edward
