Activity Forums Zaxwerks proanimator- where is it
  • proanimator- where is it
    Posted by Dirk on September 22, 2006 at 5:00 pm
    The whole folder is located in the AE plug-ins folder but now I cant find how to use Proanimator inside AE as a plug-in. Im assuming its shouuld be at the bottom list in my effects drop down menu but its not. I also did a search in the effects and presets palette with no luck.
    It works fine as a standalone app. So where is it inside After Effects?
    Thanks.
    Jon Okerstrom replied 19 years, 11 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    September 22, 2006 at 5:53 pm
    There should be a Zaxwerks item in your effects menu. ProAnimator should be one of the elements inside that… assuming you might have some of the other cool plugins.
    Jon
