Activity Forums Zaxwerks ProAnimator render problems…jagged alpha edges + AE antialising problem
  • ProAnimator render problems…jagged alpha edges + AE antialising problem
    Posted by Cabbecabbe on November 3, 2005 at 3:58 pm
    two problems…
    first.
    when i render a animation from ProAnimator with alpha the egdes are very jagged….i tried all of the diferent render settings but none of them looks good. How do i get a render with nice alpha edges??
    second
    when i import a ProAnimator made .mov into After Effects the file again looks jagged…and not just the egdes. The whole file looks like it’s not antialised. I tried exporting from ProAnimator without fields…upper fields…lower fields….but it all looks bad
    if i open the .mov in quicktime everything is clear and antialised…so i must be importing the file wrong???
    Mark Frost replied 17 years, 7 months ago 4 Members · 4 Replies
  • Jon Okerstrom
    November 7, 2005 at 5:11 am
    Hi CabbeCabbe,
    When you import the ProAnimator file, take a look at the interpret footage settings for After Effects. Be sure the field order and alpha channel settings are correct.
    Does this help?
    Jon
  • Cabbecabbe
    November 8, 2005 at 12:37 pm
    that helped! thanx alot…
  • Michael Nilsson
    January 16, 2006 at 9:40 pm
    I don’t understand this. I have the exakt same problem and none of the checkboxes in “Interpret footage” solves the problem. I have a 720×576 PAL quicktime file from PA that looks very bad in AE. I want to preserve the alpha. What should my settings be like?
    Regards, Mike
  • Mark Frost
    January 22, 2009 at 10:59 am
    What should the settings be in interpret footage?
    I am getting the jagged edges whatever I pick?
