Activity Forums Zaxwerks proanimator 90 % rotate
  • proanimator 90 % rotate
    Posted by Daveyg on October 7, 2006 at 10:20 pm
    hey all I am working with proanimator and want to do a 90 degree rotation. how do I change the anchor point so that the text doesnt rotate in center but at the bottom.
    Imagine the text being on the floor flat and then because of a lightning pass they rotate off the ground to reveal to logo. They would rotate in the middle
    Jon Okerstrom replied 19 years, 11 months ago 2 Members · 1 Reply
  • Jon Okerstrom
    October 8, 2006 at 2:13 pm
    Hi Daveyg,
    My first thought was maybe you could add an object immediately below the text, the same height as the tallest letter and make that object invisible, either by 100% transparent materials or by selecting the object and clicking the visibility box.Create a second pose then rotate all of the objects on their common center.
    The common vertical center should be at the bottom of the text.
    Jon
