Activity Forums Zaxwerks Proanimator 4.1.0 plug-in crashes AE 7
  • Proanimator 4.1.0 plug-in crashes AE 7
    Posted by Cjackson1 on January 24, 2007 at 7:18 pm
    Trying to open an AE project that contains a layer with ProAnimator as an effect crashes AE.
    Error reads “After Effects error: crash occured while invoking effects plug-in “ProAnimator”.
    There are 4 layers that are utilizing the ProAnimator effect (we’ve got it as a plug-in).
    Tried to open project on a different station and same thing happens.
    Station 1
    Mac OS X version 10.4.8
    Dual Processor 533Mhz
    Power PC G4
    Memory 1.5GB SD RAM
    Station 2
    933 MHz Power PC G4
    2 MB L3 cache
    1.5 GB SDRAM
    Worked great when I had only 1-3 layers that had ProAnimator as an effect. When effect was applied to a 4th layer the AE crashes began. AE still works great on projects that do not contain ProAnimator as an effect. Open GL is turned off
    Looked through similar posts with this problem and crash still occurs.
    Don Sligar replied 17 years, 11 months ago 3 Members · 2 Replies
  • Matt Rhodes
    January 26, 2007 at 7:30 pm
    Hello CJackson1.
    I’ve contacted you offline to see if we can resolve this issue.
    Feel free to contact me at: matt@zaxwerks.com
    Matt Rhodes
    Zaxwerks, Inc.
  • Don Sligar
    October 7, 2008 at 3:57 am
    I am on a PC with AE CS3 and a similar thing happens to me when I use PA withing AE as an effect. The PA screen freezes. I can not get out unless I stop it with ctrl/alt/delete. Then it wrecks my AE and the project.
