Activity Forums Adobe Premiere Pro pro3 ext monitor
  • pro3 ext monitor
    Posted by Zeban Bloch on July 27, 2009 at 4:22 pm
    i am runing the pro 3 with the nvidia g.f.9800
    motherbord pq5 turbo
    cupture by firewire
    how can i connect an externel monitor while editing
    zeban
    Vince Becquiot replied 17 years ago 2 Members · 1 Reply
  • Vince Becquiot
    July 27, 2009 at 6:32 pm
    You can set your second screen as an extended display, then select it in the Premiere playback settings.
    Keep in mind that, depending on the card, you may not be able to correct the aspect ratio if it doesn’t match the monitor’s.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
