Activity Forums Adobe Premiere Pro Pro vs. 6.5
  • Pro vs. 6.5
    Posted by Point&shoot on July 20, 2005 at 6:47 pm
    Hello all. I just upgraded my computer to Pro, and I really like it alot. it has a more professional feel to it. I know I am a little late in upgrading, but better late than never. Anyway my question is how do I get my plugins to show up. I have Boris Red and a couple of programs from Crystal grapics that ran fine and showed up in 6.5 that are not showing up now. Any help is appreciated.
    Mike Velte replied 21 years, 2 months ago 3 Members · 4 Replies
  • Aaron Strader
    July 20, 2005 at 7:24 pm
    Assuming you’ve got current versions of everything, check out the plugins folder in your system.
    C:\Program Files\Adobe\Premiere Pro 1.5\Plugins
    If they don’t show up in that folder, try a reinstall, and tell them to look in that folder for installation.
    For the purpose of upgrading between versions, your plugins won’t simply be there on an upgrade. You can try to copy them out of your Premiere 6.5 folder and see which ones work, but a reinstall would be recommended.
    -Aaron
    https://www.stopfcc.com/
    Knock it off! I like my radio and television the way it is…
  • Mike Velte
    July 21, 2005 at 7:45 pm
    I doubt that they will work, even if you can copy paste them from your 6.5 plug-ins folder to the correct folder in 1.5;
    C:\Program Files\Adobe\Premiere Pro 1.5\\Plug-ins\en_US
  • Point&shoot
    July 22, 2005 at 6:06 pm
    I have the disks. Will a clean install work for the plugins?
  • Mike Velte
    July 22, 2005 at 8:58 pm
    That might work, if the versions of Boris, etc are for Pro 1.5 and not limited to 6.5 or 7.0/1.0 because the folder structure changed with 1.5 as noted above.
