Activity › Forums › VEGAS Pro › Pro Type Titler: no edit window?
  • Pro Type Titler: no edit window?
    Posted by Matt Gray on June 24, 2009 at 12:05 am
    I’m using Vegas Pro 9 and am brand new to it. I’m trying to use the titler and I don’t seem to get the pro type titler to pop up when I drag it down to the timeline from the media generator. Every tutorial I see has it just popping up right away but I’m missing something there.
    Help?
    Matt Gray replied 17 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    June 24, 2009 at 1:47 pm
    It could be popping up off screen? Is it possible you dragged it off screen at one point? The only thing I can think of is to reset Vegas but that will loose any customizations you have done in the preferences. You do this by holding down Ctrl+Shift while you start Vegas. It should reset Vegas back to the settings of the first time you installed it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Matt Gray
    June 24, 2009 at 3:10 pm
    Thanks for the settings reset tip! It didn’t fix my problem (oddly) but I just re-installed Vegas and it works like it should. I must have messed up something before.
    Thank you for your help!
