Activity Forums AJA Video Systems Pro Tools and KONA LH
  • Erik Mickelson
    May 6, 2009 at 2:02 am
    Anyone here get the LHe to work as a VO input using a desktop mixer(Mackie 1202). Signal path is- Mic/Mackie/Analog in to LHe = huge latency.(I monitor from the LHe AES direct to my speakers which have digital inputs).
    I have a Metric Halo setup that has much zero latency but that is at the downtown studio.
    MacPro Dual Core 2 Duo 3.0Ghz, 6GB ram, 1TB Raid, Tiger 10.4.11, FCPStudio 2
  • Gary Adcock
    May 6, 2009 at 1:13 pm
    [Erik Mickelson] “Anyone here get the LHe to work as a VO input using a desktop mixer(Mackie 1202). Signal path is- Mic/Mackie/Analog in to LHe = huge latency.(I monitor from the LHe AES direct to my speakers which have digital inputs). “
    Erik.
    3 posts about how you have issues with “hugh latency” but to for anyone here to be able to solve this issue you will need to be VERY SPECIFIC about what FCP/ QT/ OS versions and what driver version you are running.
    Most of the time issues like this can be attributed to improper installation of the Kona Driver and the associated firmware update (which must be done manually on all kona Pci/e cards)
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Erik Mickelson
    May 6, 2009 at 4:04 pm
    Thanks for the hint on the software Gary. I did a full AJA software uninstall and reinstall. Latency is low again!
    Thanks Cow!
    MacPro Dual Core2Duo 3.0Ghz, 6GB ram, 4TB SATA Raid, Tiger 10.4.11, FCPStudio 2, QT 7.5.5
Page 2 of 2
