Activity Forums Audio Pro Tools and DAC100
  • Pro Tools and DAC100
    Posted by Al_egoboo on August 20, 2007 at 3:58 pm
    I am running protools HD3 on a Mac G5. I am sending the video out to a Datavideo DAC100 Card and then going into an LCD TV via component video. But I am only getting a black and white signal.
    Can anyone help?
    Alan.
    Peter Groom replied 19 years, 1 month ago 3 Members · 2 Replies
  • Ray Palmer
    August 20, 2007 at 11:26 pm
    [Al_egoboo] ” Card and then going into an LCD TV via component video. But I am only getting a black and white signal.”
    I am not familiar with your I/O or monitor but I have seen this a dozen times. If you are sending analog component output and your monitor is set for composite, you will get B&W. The green channel is the luminence channel and it only has black and white information.
    Check to make sure that your monitor is also set to component, not composite.
    Ray Palmer, Engineer
    Salt River Project
    Phoenix, AZ
    602-236-8224 office
    There are three types of people in this world, those that can count and those that can’t.
  • Peter Groom
    August 23, 2007 at 9:19 am
    Yep, component is separates, composite is all signals composited into 1 video signal which is where the problem will lie.
    Look for a non rgb input
    Peter
