Activity Forums VEGAS Pro Pro Titler keeps turning red anytime I attempt to edit text
  • Pro Titler keeps turning red anytime I attempt to edit text
    Posted by James Donovan on April 19, 2011 at 2:27 pm
    Good morning
    This has been bothering me for awhile. I’m working with the Pro Titler and I have something pretty much completed. I wanted to add a point where the text changes from one color to another. Whenever I try to make a selection from within the text editing, the whole preview screen turns red and you can’t see anything. The timeline now also shows big red squares – as if they were generated media. Have you ever seen anything like this? Thanks a million.
    James Donovan replied 15 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    April 19, 2011 at 8:25 pm
    Wow, I’ve never heard of generated media causing red frames. Usually red frames are caused by your system running low on resources. You might want to reboot, and then create a new project and test this out to see if it’s just a problem in your current project or if it’s a bigger problem that should be reported to Sony.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • James Donovan
    April 20, 2011 at 1:39 pm
    As always, thank you.
