Activity Forums Compression Techniques Pro Rez Question
  • Pro Rez Question
    Posted by Jeff Barringer on September 12, 2011 at 5:56 pm
    Hello all,
    I’m adding a close captioning file to an existing pro rez file – using compressor – pretty straight forward. Except, the resulting pro rez file has a white bar along the bottom and right had side. Yet the image size itself seems to correct. Is there an explanation for this?
    Thanks for your thoughts!
    Cheers,
    Jeff
    Mac tower
    FCP
    All pretty current
    Andrew Saliga replied 15 years ago 2 Members · 1 Reply
  • Andrew Saliga
    September 20, 2011 at 5:02 pm
    Are you sure you’re just not seeing the CC data track?
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
