Activity Forums Apple Final Cut Pro Legacy Pro Res?? Using Compressor?
  • Pro Res?? Using Compressor?
    Posted by Elliot Pollaro on July 20, 2007 at 8:12 pm
    I am wanting to convert my 720p footage from my P2 cards using compressor into a ProRes format, so I can let one of my editors edit with his laptop. It should compress it down keeping the same quality…. Well when I compress it, the file size gets larger. What am I doing wrong?
    Tom Wolsky replied 19 years, 2 months ago 4 Members · 4 Replies
  • Uli Plank
    July 20, 2007 at 8:16 pm
    DVCProHD is only 100 mbps, ProRes has more.
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Elliot Pollaro
    July 20, 2007 at 8:48 pm
    so theres no way to do what I was planning?
  • Shane Ross
    July 20, 2007 at 9:01 pm
    DVCPRO HD is perfectly editable on a laptop. Just get a firewire 800 drive and you are good to go.
    ProRes is a low data rate substitute for UNCOMPRESSED HD, not DVCPRO HD. DVCPRO HD is a compressed form of HD.
    Compressing to ProRes would be good when you get to the color correction phase…as it is a 10-bit codec and DVCPRO HD is an 8-bit codec. But that is when you are DONE editing.
    Just give them the DVCPRO HD files on a FW800 drive and they should be good to go.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tom Wolsky
    No point, not if you’re trying to save drive space.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
