Activity Forums Adobe Premiere Pro Pro Res won’t work out of Premiere CS6 even after I’ve installed compressor
  • Pro Res won’t work out of Premiere CS6 even after I’ve installed compressor
    Posted by Tj Hellmuth on March 15, 2013 at 3:21 pm
    I’m new to premiere comming from FCP7 and I’m really not getting it’s export settings. Nothing too desirable in this candy box to me yet. I want to be able to export a nice master, that isn’t so large that its unplayable. ProRes completely fits the bill for this, so I’ve installed compressor to get the Pro-Res elements, I’ve downloaded the Pro-res preset group, but I’m still getting this error that stops me from exporting anything in Pro Res:
    Incompatible Video Codec found in the Prest. Preset load failed.
    Does anyone either know how to solve this problem? do i have to re-install premiere AFTER compressor has been installed?
    If nobody knows, is there a setting that is good for mastering my 5K epic footage? The easiest method right now is to use the native sequence settings which are in MPEG format, but I don’t know if thats master quality or not.
    TJ
    Kevin Monahan replied 13 years, 6 months ago 3 Members · 3 Replies
