Activity Forums Apple Final Cut Pro Legacy Pro Res won’t Open
  • Pro Res won’t Open
    Posted by Russell Levenson on April 7, 2010 at 3:57 pm
    Is there a reason neither Final Cut NOR Quicktime will open my pro res file? Here’s the name of the file [Pekurny’s Sequence Copy-“Consumed” Project – Pro Res-Apple Intermediate Codec (AIC).mov_NTSC_4000]
    It won’t open in Final Cut or Quicktime. I’m currently converting it to h264, but it SHOULD open by itself shouldn’t it?
    Thanks.
    Jason Diebler replied 16 years, 5 months ago 4 Members · 4 Replies
  • Rafael Amador
    April 7, 2010 at 4:30 pm
    [Russell Levenson] “[Pekurny’s Sequence Copy-“Consumed” Project – Pro Res-Apple Intermediate Codec (AIC).mov_NTSC_4000]”
    What is that?
    You do not mean that this is the name of a file, don’t you?
    Rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    April 7, 2010 at 4:55 pm
    Sounds like it’s AIC not ProRes.
  • Russell Levenson
    April 7, 2010 at 5:27 pm
    I’ll admit I don’t completely understand video codecs. I’m just trying to get the audio, but even after converting to h264 the audio won’t work.
  • Jason Diebler
    April 7, 2010 at 7:14 pm
    Try a file name that makes a bit more sense… like one that doesn’t have special characters, maybe is a little shorter, and simply ends in .mov
    Get Info on the file to see what file type it is.
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
