Activity Forums Compression Techniques Pro Res to MPEG-2 issue
  • Pro Res to MPEG-2 issue
    Posted by Elliot Beach on May 9, 2012 at 12:07 am
    I’m getting a very a annoying issue when using compressor.
    I have a 04:80 second apple pro res export form final cut, which I am then importing into compressor and applying the DVD SD mpeg-2 best quality template so I can burn to a DVD.
    The compression goes through successfully, however when I play the mpeg file through quicktime it takes about 10 seconds to play and says the duration is 2 hours long. The video is there in the first 5 minutes but it keeps going with a black screen for 2 hours. If I try to burn this to disc any other video before it plays fine but when the track with this file comes it does nothing and restarts.
    I’m using the default DVD settings in compressor and have tried high bit rate and lower but still does the same issue. The apple pro res file seems to have nothing wrong with it. Also, if I cut a fragment of the video and export using FCP and compress that it seems to work fine with the correct duration.
    Not sure what the problem is, any help would be great?
    Jeff Greenberg replied 14 years, 4 months ago 2 Members · 2 Replies
  • Elliot Beach
    May 9, 2012 at 9:45 am
    Note this is also happening with a 8 minutes clip also exported in pro res. I have tried uninstalling compressor and reinstalling. Still have the problem!
  • Jeff Greenberg
    May 20, 2012 at 2:09 pm
    Let’s try this two ways.
    1) Send the file to compressor from FCP. This is the ‘cleanest’ communication between the 4 min sequence and the end MPEG file.
    2) Try exporting a QuickTime movie and then punch it over to compressor.
    They should both give you the same result – a 4 min movie….or not. Let’s find out!
    Best,
    Jeff I. Greenberg
    Editor/Author/Speaker/Consulting
    My NAB seminar schedule, contact info and more
