Activity Forums Apple Final Cut Pro Legacy Pro RES to Digibeta
  • Pro RES to Digibeta
    Posted by Lance Bachelder on November 16, 2007 at 8:06 am
    Cutting a CG show at 720p 23.976 using Pro RES HQ codec. I need to output to NTSC Digibeta at 29.97 df. No matter what settings I use I get compression error window when attempting edit to tape. Tried setting up new NTSC seq and nesting and or copying HD show into that seq – no luck.
    Any suggestions on proper settings for timeline, output etc? Using Kona LHe and Kona 3 with FCP 6.01 on both machines.
    Lance Bachelder
    Southern California
    Lance Bachelder replied 18 years, 9 months ago 2 Members · 2 Replies
  • Shane Ross
    November 16, 2007 at 8:09 am
    This error?
    #18 Edit to Tape “Incompatible Compression Settings”
    Shane’s Stock Answer #18
    To Edit to Tape you either need to have your sequence loaded in the VIEWER, or simply drag it from the BROWSER onto the Edit to Tape window and choose Assemble Edit or Insert Edit.
    For both methods, the tape needs to be black and coded and have TC already on it. And you need to mark and IN point in the ETT window.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Lance Bachelder
    November 16, 2007 at 8:31 am
    That’s the error!
    Will try your advice.
