Activity Forums Apple Final Cut Pro Legacy Pro res rendering problem
  • Pro res rendering problem
    Posted by Matthew Levett on May 27, 2011 at 5:53 am
    Hi there,
    I’ve down converted some H.264 files in Pro res.
    Here are the stats…
    Format – Apple ProRes 422, 480 x 270, Millions
    16-bit Integer (Big Endian), Stereo, 48.000 kHz
    FPS – 25
    SIZE – 480 x 270 pixels (Actual)
    Problem is , when I put them in FCP 7 sequence and put any effects (slow mo, dissolve) the red comes up and i have to render all the time. can i change something in the settings? Any suggestions?
    David Roth weiss replied 15 years, 4 months ago 4 Members · 3 Replies
  • Everest Mokaeff
    May 27, 2011 at 7:00 am
    Time-line upper left corner: Switch Safe RT for Unlimited RT. By the way, this is bad resolution you are gonna edit there. Try to use more conventional (SD/HD) formats as your footage sources.
    Free-lance fcp editor in Moscow
    http://www.mokaeff.com
  • Shane Ross
    May 27, 2011 at 7:21 am
    480×270 is not a real time pixel aspect ratio. FCP is designed to work with broadcast video formats. And those frame sizes are 720×480…or in PAL land, 720×576. Yes, you footage is ProRes, but the dimensions are the issue.
    If you want to work without much rendering, you need to convert to the PAL SD dimensions.
    Shane
  • David Roth weiss
    May 27, 2011 at 3:04 pm
    [Matthew Levett] “I’ve down converted some H.264 files in Pro res.”
    No, you either transcoded or possibly, in this case at least, up-converted.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
