Activity › Forums › Apple Final Cut Pro Legacy › Pro Res question
  • Pro Res question
    Posted by David Levy on November 8, 2010 at 11:30 pm
    If I have a Pro Res 422 sequence with clips attached, and I change it to a 422HQ sequence, what actually changes? The existing clips in the sequence, or only future things brought into that timeline, or what?
    I am trying to compare the same clips in ProRes 422 and PrRes 422HQ to see what difference we can detect, if any.
    Thanks so much
    Rafael Amador replied 15 years, 10 months ago 4 Members · 4 Replies
  • Tom Wolsky
    November 9, 2010 at 12:52 am
    The only thing that changes is the codec in which the material is rendered. If the material is ProRes and you change the sequence settings to HQ, everything has to be re-rendered to conform to the new codec. Unless your media is in film resolution you most likely have no need for HQ.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Jeff York
    November 9, 2010 at 6:21 am
    Final Cut, in general, tries to operate in a non-destructive way. As Tom Wolsky writes, what you are seeing is the output of the timeline which FCP will want you to render since you changed the codec. At that point, you are seeing ProResHQ after FCP has created a separate render file that it’s playing back from. Since ProResHQ has a higher data rate than ProRes, you will not likely see a difference. It’s a little like taking a VHS tape and dubbing it to digibeta. You won’t really lose anything in the dub, but it’s still going to look only as good as the original.
    In order for your experiment to yield useful results, you will need to take a file with a higher data rate than ProResHQ can handle (like 2k). Then convert from the original file into both ProResHQ and ProRes using Compressor.
    Also echoing what Tom wrote, it’s unlikely you will need all the bandwidth that HQ provides unless you’re dealing with some really high end original footage (like film). For local TV broadcast, I’ve been very happy saving space and using ProResLT. It’s still a higher bandwidth than the transmitter uses. I just make sure not to go tossing out the original footage.
  • David Levy
    November 9, 2010 at 2:52 pm
    Thanks Tom & Jeff.
    Will do your ‘test’ suggestion jeff.
    note: When I changed the sequence to HQ it doesnt show up as needing to re-render the current pro res clips. I also created a new sequence in the same project and it too didnt seem to require a re-render oft he 422 clips up to HQ. What am I missing?
  • Rafael Amador
    November 9, 2010 at 4:53 pm
    [David Levy] “note: When I changed the sequence to HQ it doesnt show up as needing to re-render the current pro res clips. I also created a new sequence in the same project and it too didnt seem to require a re-render oft he 422 clips up to HQ. What am I missing?”
    You have RT performance, but the sequence needs to be rendered on exporting.
    rafael
    http://www.nagavideo.com
