Activity Forums Adobe Premiere Pro Pro Res Output in Windows
  • Pro Res Output in Windows
    Posted by Brogan De paor on March 15, 2021 at 12:11 am
    I am exporting a Pro Res 422HQ file from P P on a windows machine. The footage was shot in 1080i and imported as MPEG 2. If I use the “match source” settings it produces a file that plays
    “squeezed”, in 4×3. (It says 1.333 anamorphic.) If I set the pixels as “square” (1.0), it comes out 9×16, but does not fill the frame. How can I get a better output? Thanks.
    Brogan de Paor
    Brogan De paor replied 5 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Wise
    March 15, 2021 at 12:38 am
    What is your sequence setting?
  • Brogan De paor
    March 15, 2021 at 12:43 am
    1440×1080;(1.333); 29.97; upper
  • Jerry Wise
    March 15, 2021 at 12:53 am
    What would happed if you copied your 1440×1080 sequence to a new sequence that was 1920×1080 square pixels?
  • Brogan De paor
    March 15, 2021 at 1:10 am
    I’ll try it! Thanks .
  • Jerry Wise
    March 15, 2021 at 6:13 pm
    Did it work ?
  • Brogan De paor
    March 15, 2021 at 6:27 pm
    Unfortunately, I could not make the program allow me to set the sequence specs as 1920×1080.
    they stayed at 1440x 1080, so it didn’t quite work. Which I guess raises the question of why I couldn’t do it? But thanks anyway.
  • Ann Bens
    March 15, 2021 at 9:02 pm
    Sometimes you need to set the sequence to Custom first before you can change a property.
    But you dont need to change the sequence you can export directly to 1920×1080.
  • Brogan De paor
    March 15, 2021 at 9:45 pm
    Thanks to both of you for your help. It turns out that (building on Jerry’s suggestion), if I create the new sequence, but as an XD Cam 422 1080i, it will be in 1080×1920 and exports as such!
    I haven’t tried Ann’s approach as yet, but will do so. Thanks again.
    Brogan
