Activity Forums Blackmagic Design Pro Res Minimum Hardware Requirements
  • Pro Res Minimum Hardware Requirements
    Posted by Chris Borjis on May 29, 2007 at 4:15 pm
    I’m starting to hear now that you have to have a Dual Core Mac PRO (INTEL) system to be able to even capture Pro-Res in HD.
    Is this true?
    Can I capture from a multibridge extreme into a PCI-E equipped G5 Quad system with a 4gb fibre channel array?
    If not this will be a HUGE disapointment, this system is barely a year old.
    Chris Borjis replied 19 years, 3 months ago 2 Members · 4 Replies
  • Sean Oneil
    May 31, 2007 at 7:20 am
    You might be disappointed then. Quad G5 MIGHT be ok from what I’ve been hearing. But that is the bare minimum for HD (if it even works).
    I have a dual G5. ProRes works with standard def, but barely. Both CPUs climb up to 80% during capture, and about 60% during playback. First time trying to output to tape, I got a dropped frame error. This is standard-def mind you. Not even going to attempt HD.
    When I was at NAB, the people there told me I should be fine, my G5 should work no problem, yadda yadda. Total BS.
    Sean
  • Chris Borjis
    May 31, 2007 at 2:45 pm
    yeah this whole Pro-Res with HD on a G5 architecture has been a very silent thing I’ve noticed.
    I have yet to know anyone with a G5 quad that has tried it.
    I’ll have fcs 2 on friday and will post results monday.
  • Sean Oneil
    June 1, 2007 at 4:59 pm
    Cool, look forward to it. But shouldn’t this discussion go in the Final Cut forum?
  • Chris Borjis
    June 1, 2007 at 5:04 pm
    Yeah, I’ll post it there.
