Activity Forums Apple Final Cut Pro Legacy Pro Res Import
  • Posted by John Hill on February 27, 2011 at 4:37 pm
    My Pro Res file stutters in the browser. The file started out as an h264 – converted the file by exporting as ProRes in QT7. It stutters in Browser but plays fine in the timeline? So I can continue to cut with it in the timeline but when I export to a quicktime it does not show me what is in the timeline, which makes editing useless.
    And if I drop the pro res directly into my timeline it plays beautifully. The only problem is that when I match back it doesn’t match back to the same frame and when I make a quicktime of the timeline it’s not the same as the sequence.
    Pro Res frame rate 23.98 and size 853×480 matches sequence settings of 23.98 and size of 720×480 with anamorphic checked.
    Importing ProRes file from a firewire drive -G-Tech 1 gb Raid – using 800 firewire)
    Mac Pro OS 10.5.8
    FCP 7.0.3
    Dual-Core Intel, 2.66 GHz, 6 GB Ram
    John Hill replied 15 years, 7 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    February 27, 2011 at 6:15 pm
    You need to match your sequence settings to the source clips’ properties. They don’t match… Create a new sequence, put one of the prores clips in it, and click on the option to match the settings.
    Since you can’t really play clips in the Browser, I don’t quite understand the problem, but matching sequence settings has to happen for sure.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • John Hill
    February 27, 2011 at 6:54 pm
    Appreciate your help, Jerry –
    I did that…to reiterate this is my Pro Res setting: frame rate 23.98 and size 853×480.
    My sequence setting has the same frame rate 23.98 and the size is 720×480 with anamorphic checked since FCP has no Sequence size to exactly match the Pro Res size of 853×480.
    If I drag the Pro Res file into the sequence from its home on a firewire drive it plays perfectly in the sequence. However, when I import it into the Browser, it stutters in the Viewer.
    And, if I use match back from the Timeline, it does not work correctly – matches back to a different frame. This would make it impossible to make a DVD etc.
    Thanks for your help.
  • Jerry Hofmann
    February 27, 2011 at 8:52 pm
    John, you can make any sequence setting you wish. You can type cmd+zero to open a sequence’s settings, then set the frame size and pixel shape (probably square) to match.
    You don’t have the same frame sizes there… When you create a new sequence, is this what FCP creates when you click yes to conform the sequence setting to the clip’s properties?
    Jerry
    Current DVD:
  • John Hill
    February 27, 2011 at 11:53 pm
    Yes, the sequence settings are what FCP creates when I place the clip in the timeline. The size on both the Pro Res and in the sequence setting is the same 720 x 480 – Sorry for the confusion about the 853×480 size of the pro res- it was in parentheses next to 720×480.
    So the clip plays fine in the sequence but won’t match back correctly and stutters when playing in the Viewer.
    Thanks for any further insight.
