Activity › Forums › Apple Final Cut Pro Legacy › Pro Res 422 vs. DVCPRO 50 (Revisited) workflow
  • Pro Res 422 vs. DVCPRO 50 (Revisited) workflow
    Posted by Sean Kapleton on March 16, 2008 at 9:12 pm
    Hey everyone,
    I read some of the threads about comparing these two codecs and I just have a quick question for anyone willing to help me out.
    I have a huge batch of Camera RAW file sequences which i will be turning into QT movies in AE7 in order to edit with. I will work in two streams 1 being offline and the other set will be in the animation codec for once picture isl ocked.
    I have done a batch automation in Photoshop scaling the raw files down to 1920×1080 for FCP now i just am not sure whether or not to make them Pre Res 422 or DVCPRO 50 for editing purposes – i noticed there a bunch of different dvcpro codec options too but i dont know what to do. When the edit is locked i will replace the footage with animation qt’s in order to deliver to animators and 3d artists a full res edit.
    My other question is about how once picture is locked i can best replace the footage with animation qt’s – i believe i just take the footage offline and replace with the qt’s that are identical in name but in the animation codec – i also think i will have change the seq setting compression to animation.
    thank for any help you guys can provide me with
    best
    sean kapleton
    Macpro dual 2.8 8 core
    4gb ram
    2x 750gb sata drives
    Sean Oneil replied 18 years, 6 months ago 2 Members · 1 Reply
  • Sean Oneil
    March 16, 2008 at 10:50 pm
    You don’t use either if you’re going to replace all the footage anyways for the online. You can use DV25 or OfflineRT Jpeg.
    When you create your offline movies and your Animation movies, make sure the timecode is the same for both. It’s probably a good idea to assign reel names to them as well.
    Sean
