Activity Forums Apple Final Cut Pro Legacy Pro res 422 render problem!
  • Pro res 422 render problem!
    Posted by Michael Unger on February 21, 2012 at 2:01 am
    My issue is the following:
    My footage is in Pro Res 422 (1920×1080). My sequence is Pro Res 422 (1920×1080) with Unlimited RT. Every time i make a cut i have the render out the orange or else i get a slow playback. What am I doing wrong?
    Erik Lindahl replied 14 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    February 21, 2012 at 3:03 am
    Multicam? Have a filter on the footage? resized? Somethings not right. Not matching up exactly
    Shane
    Little Frog Post
  • Erik Lindahl
    February 21, 2012 at 12:22 pm
    Also check that if the media is interlaced or progressive and make the same change to the timeline. If the ProRes-files originate from an odd source – double check their frame rate as well. I’ve seen 24.xx FPS when dealing with 25 fps footage for example. This is something FCP won’t like.
