Activity Forums Apple Final Cut Pro Legacy Pro Res 422 options?
  • Pro Res 422 options?
    Posted by Kent Beeson on October 7, 2008 at 7:01 pm
    Hi
    Recorded in HDV 1440x1080i 60, captured Pro Res 422…question is: For my sequence settings (currently Pro Res 422) what do I do about the advanced options under General tab, ie, it gives you the option to check or uncheck Interlaced – should I uncheck it? Will that make it progressive? If so, do I need to set Field Dominance to “NONE”? What’s best quality for final delivery, NTSC DVD and web.
    What about the “enable 4:4:4 chroma filtering” option in compression settings – what is that and should I check or uncheck it?
    Lastly, in Video Processing tab, should I choose Render in 8-bit YUV? Or what?
    K
    web.me.com/kbcv
    Chris Borjis replied 17 years, 11 months ago 2 Members · 1 Reply
  • Chris Borjis
    October 7, 2008 at 10:01 pm
    Leave everything as is.
    changing something could lead to problems.
