Activity › Forums › Apple Final Cut Pro Legacy › Pro Res 422 – Love it or Hate it?
  • Jeremy Garchow
    July 27, 2007 at 1:52 pm
    [blueflamez] “Any thoughts?
    A couple:
    You are running that lvery latest Kona drivers I take it for FCP 6?
    https://www.aja.com/ajashare/Kona3_Software_4.0.tar
    PCIe expansion slot is setup properly?
    Call AJA? Something is not right with your setup.
  • Matt Steeves
    July 30, 2007 at 2:50 pm
    Have the latest drivers…everything else with my FCP works just fine. I have a call in to AJA.
    Anything else I can try in the mean time?
  • Connie Simmons
    November 2, 2007 at 8:21 pm
    HI, Matt – I had the same problem with ProRes HQ and discovered one problem – although not a solution. Every 21 -23 frames there is a duplicate frame and then it skips one frame, so it in effect stutters. I am still trying to figure this out.
    For example: These are the frames: 1 2 3 3 5 6 7 8
    Best, Connie
  • Jeremy Garchow
    November 2, 2007 at 9:06 pm
    What format and frame rate was this footage shot from and what deck are you capturing from?
  • Gary Adcock
    November 3, 2007 at 12:34 pm
    [conniesim] “I had the same problem with ProRes HQ and discovered one problem – although not a solution. Every 21 -23 frames there is a duplicate frame and then it skips one frame, so it in effect stutters. I am still trying to figure this out.”
    This is a hardware issue, Prores needs a huge amount of horsepower and if the RAM, CPU, GPU and storage are not fast enough in combination your will get dropped frames.
    in the digital world – the OS / NLE will hold a frame until the signal stabilizes your dupe frame is most likely that- and means your setup is not meeting the requirements for capture.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Connie Simmons
    November 3, 2007 at 12:46 pm
    Hi. Here is my setup:
    3 gig 8 core Mac Pro – 8 gigs ram (tried it with just 2 gigs – no difference)
    Kona 3 card – latest drivers from website.
    e sata raid – 160 MB write and 176 mb read on AJA System Test
    Cal Digit fasta-4e raid adapter card
    FCS – latest update. Tried it before and after latest update, and before and after QT 7.02 update.
    JH-3 deck. – Anyone have problems with this deck?
    Should be fast and big enough.Just doesn’t make sense to me.
    Thanks, Connie
  • Gary Adcock
    November 3, 2007 at 11:42 pm
    Sorry dude
    I am at a loss…
    try 2 things-
    turn off the Time Synchronization (this has been know to cause drop frames)
    turn off your network connection
    gary adcock
    Studio37
  • Jeremy Garchow
    November 3, 2007 at 11:55 pm
    I am really sorry to have to ask this question, and I might sound silly for doing it but,
    Are you sure it’s not just 3:2 pulldown?
    Jeremy
  • Jeremy Garchow
    November 4, 2007 at 12:03 am
    …and you have also run the Expansion Slot Utlity.app and selected option 2?
  • Connie Simmons
    November 4, 2007 at 3:40 am
    Hi. What is the issue with time synchronization? I haven’ heard about this?
    Thanks.
    Connie
Page 2 of 3
