Activity Forums Adobe After Effects Pro Import with XML not working properly…linking fails
  • Pro Import with XML not working properly…linking fails
    Posted by Hans Meier on December 2, 2014 at 2:36 pm
    Hey guys,
    I had this workflow running with no problems for some time, but all of a sudden I can’t manage to do my beloved workflow anymore. Here is what I do:
    1) editing on avid media composer
    2) EDL conform in Resolve to grading DPX-sequences
    3) Export XML for After Effects
    4) Pro Import the XML in AE with the proper folder for the source-files
    After Effects has no problems doing the conform and everything looks fine, but he does not link or find the source files. When I manually connect the offline-media everything is fine. But this is a LOT of work for a 5 minute movie. Like I said – I used this workflow with no problems for a couple of time. I can’t really remember, but I think this problem happened when I switched from CC to CC 2014.
    I tried the same workflow also in CS6 and CC. Same problem.
    The entry in the XML is totally fine. Seems that AE has some problems with the DPX sequences. I tried a test-cut and used Quicktimes for the conform in Resolve. Then I’m able to do a full conform in AE afterwards with no problems. Again – it worked with DPX seqs before.
    I’m out of options…tried a lot of stuff to solve this…any ideas???
    Cheers
    Hans Meier replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
