Activity › Forums › Apple Final Cut Pro Legacy › Pro Deck for Canon 24F
  • Pro Deck for Canon 24F
    Posted by Mark Grieco on April 17, 2011 at 3:28 pm
    Hello,
    I’ve been shooting a documentary on an XHA1 at the 24F frame setting. I’m having problems capturing my footage with my camera and I’m searching for a pro deck that can play back that 24F footage. I’ve been told before, years ago when I first bought the camera, that the Canon 24F was a proprietary format and that, at that time, there were no pro decks manufactured that could play back the footage.
    I believe I have a recording problem with one of the tapes and need a pro deck to see if any of the footage is salvageable.
    Much appreciated.
    Shane Ross replied 15 years, 5 months ago 3 Members · 4 Replies
  • Rafael Amador
    April 17, 2011 at 3:37 pm
    Hi Mark,
    You only need a FireWire cable and read the FC manual.
    Best,
    Rafael
    http://www.nagavideo.com
  • Mark Grieco
    April 17, 2011 at 3:38 pm
    It’s not FCP that is the problem. It’s the actual deck I am looking for that can play back the footage shot on a Canon Xh-A1 at the 24F frame rate.
    Maybe I posted to the wrong thread but there were other similar threads about the Canon 24F in this FC forum.
    Does anyone have an answer about a pro deck that can play back that footage. Not a capture problem in FCP.
  • Rafael Amador
    April 17, 2011 at 3:59 pm
    [Mark Grieco] “It’s not FCP that is the problem. It’s the actual deck I am looking for that can play back the footage shot on a Canon Xh-A1 at the 24F frame rate. “
    You don’t need any especial desk.
    You do that from the camera with just a FireWire cable.
    Connect, logg and capture.
    rafael
  • Shane Ross
    April 17, 2011 at 5:24 pm
    Canon doesn’t make decks. And you’re right, it is a proprietary Canon format, so the SONY decks won’t be able to play it back. Playback from the camera only I’m afraid.
    Shane
