Activity Forums Apple Final Cut Pro Legacy Pro Apps Update 2007-01
  • Pro Apps Update 2007-01
    Posted by Keith Koby on July 3, 2007 at 2:22 pm
    Pro Application Update 2007-01 updates the following components
    Apple ProRes 422:
    Delivers improved encoding performance for Power Mac G5 computers.
    Anyone test to see if there quads and lower G5s can handle ProRes 422 capture with the update?
    Chris Borjis replied 19 years, 2 months ago 7 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    July 3, 2007 at 2:34 pm
    Our Quad G5 can capture ProRes HD all day long now.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Borjis
    July 3, 2007 at 3:00 pm
    No I still can’t capture 720P over component with the update
    I wish I could.
    Walter can you capture 720P 60 with ProRes?
  • Walter Biscardi
    July 3, 2007 at 3:18 pm
    [Borjis]
    Walter can you capture 720P 60 with ProRes?”
    Yep, 720/60 and 1080i/60 no problems.
  • Chris Poisson
    July 3, 2007 at 3:37 pm
    I still cannot capture 1080 with ProRes with my LH and G5 2 gig. Update no help.
  • Chris Borjis
    July 3, 2007 at 4:23 pm
    this is strange.
    my setup should work.
    G5 Quad, PCI-E model, 4GB Ram
    Ciprico 4210 4gb fibre channel array
    BMD Multibridge Extreme.
    I heard someone with a near identical setup has it working as well.
  • Mark Maness
    July 3, 2007 at 7:17 pm
    Check to see if your Blackmagic has a new set of drivers for you. Walter and I are using Kona 3s on our Mac Pro system, so we are able to do anything in ProRes 422.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Michaelle Stikich
    July 3, 2007 at 8:30 pm
    k so this confused me also. But the statement mentions “encoding” not “capturing” for G5. I went back to the apple support page to find the article about ProRes capture on Intel and found that they updated it for Quad G5s. However there is no mention of any other G5 supported for capture, so we can only assume that any other G5 won’t work. Check it out here: https://docs.info.apple.com/article.html?artnum=305582
    Its weird to use the word “encoding” tho, what does that mean? Render to ProRes? Export to ProRes?
  • Chris Paul
    July 3, 2007 at 8:37 pm
    I have a G5 quad similar to Borjis. I was able to capture to ProRes 720p60 when it first came out but now cannot capture more than 5 minutes worth at a time. Since the ProApps update I can now capture a complete tape of ProRes 1080i but still not 720p. Go figure.
    Chris Paul
    POV
  • Chris Borjis
    July 3, 2007 at 9:31 pm
    I am running the FCS2 drivers for black magic multibridge extreme,
    so I know thats not it.
    I have not tried 1080i.
    I know the person who did capture used HD-SDI not component.
    I wonder if that extra step is whats causing the problem.
    My system did manage to capture about 20 seconds of 720P 60
    before it failed.
    Prior to the update it would fail within 5 seconds.
