Activity Forums Zaxwerks Pro Animator Crashes Upon Offset of Layer Map
  • Pro Animator Crashes Upon Offset of Layer Map
    Posted by Ong Joseph on February 16, 2009 at 3:36 am
    Hi all,
    I need some help urgently. I have a basic 3d text set up which I imported from illustrator. I used the “punchy reflections” map as a layer map for the text. However, everytime I click and attempt to offset the map on the effects palette, After Effects would prompt me that there isn’t enough memory to carry out task and proceeds to close down the program, only allowing me to save a backup.
    I have tried purging but it does not help. After several attempts to restart the application, the problem still persists. Can someone help? I’m using version 4.3 of Pro Animator.
    Thanks.
    Regards,
    Joseph
    Ong Joseph replied 17 years, 6 months ago 2 Members · 2 Replies
  • Matt Rhodes
    February 16, 2009 at 7:02 pm
    Hi Joseph.
    If you can, send me your project file (only the .aep file) and I’ll take a look.
    Also send me a few steps to follow.
    Note that the current version of ProAnimator is v4.5.1. We suggest you upgrade (it’s free) if possible: https://zaxwerks.com/download
    Send files to: matt@zaxwerks.com
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
  • Ong Joseph
    February 22, 2009 at 2:45 pm
    Thank You Matt. I’ve proceeded to upgrade my product and the issue seems to be solved.
    Joseph
