Activity Forums VEGAS Pro Pro 13 rendering error message / single minute of rendering without the crash / suggestions
  • Pro 13 rendering error message / single minute of rendering without the crash / suggestions
    Posted by Brent Holland on December 6, 2016 at 9:30 am
    Pro 13
    I keep getting the following error message. I can’t even get through a single minute of rendering without the crash. Suggestions?
    Extra Information
    File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\dx_video_grovel_x64.log
    File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\svfx_video_grovel_x64.log
    File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\ocio_x64.log
    File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\dx_grovel_x64.log
    File: C:\Users\Owner\AppData\Local\Sony\Vegas Pro\13.0\gpu_video_x64.log
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 453) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Fault Address: 0x0000000000000000
    Fault Offset: 0x0000000000000000
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 453) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2015-06-05 (Fri Jun 05) 21:53:04
    László Kovács replied 9 years, 9 months ago 2 Members · 5 Replies
  • László Kovács
    December 6, 2016 at 10:59 am
    did you try to disable GPU support?
    If that helps, download and give a try to Vegas 14. (Major bugs related to GPU support are fixed in the Magix version).
    If GPU disabling does not help, you may want to give more details to the community about your project properties, source medias, and to what format you try to render to.
    Best regards
    László Kovács
  • Brent Holland
    December 6, 2016 at 11:24 am
    Thx for the quick response.
    How do I disable GPU support in Pro 13. Thx in advance
  • László Kovács
    December 6, 2016 at 11:32 am
    In options / preferences.
    Then on the video tab:
    “GPU acceleration….” set it to off, then restart Vegas.
    Best regards
    László Kovács
  • Brent Holland
    December 6, 2016 at 11:37 am
    Thx buddy, giving it a shot right now, off to bed close to 7 am in eastern canada (Kingston), see how far it gets while I’m sleeping
  • László Kovács
    December 6, 2016 at 11:45 am
    You’re welcome, especially if I could help.
    Just took my lunch break here (Central Europe)
    Best regards
    László Kovács
