Activity Forums Maxon Cinema 4D Prism Shaped moving surfaces
  • Jim Scott
    March 2, 2017 at 4:02 pm
    It looks like it might have been done using Trapcode Mir in After Effects, but a basic setup for something similar in C4D would be to add a Displacer with a noise shader to a plane and animate its position. To add the random vertical displacement increase the Animation Speed in the Shader Properties above zero. Adjust (or animate) the Height setting in the Displacer’s “Object” properties as well.
    Here’s a simple project file: 11092_displacerexample.c4d.zip
  • Bill George
    March 12, 2017 at 7:47 pm
    thanks so much Jim , I will try this out now
