Activity Forums Maxon Cinema 4D Priority Settings for Spline Dynamics
  • Priority Settings for Spline Dynamics
    Posted by Dan Fassnacht on December 14, 2012 at 4:19 pm
    Hello,
    I’ve been messing around with spline dynamics and priority settings and I’m not sure if I’m doing it right. I’m basically attaching a dynamic spline to a dynamic object, then adding an xpresso tag to each and altering the priority there. Is that the correct way to go about this? Or is there anything further I have to do in Xpresso? Any info you could provide would be great.
    Best,
    Dan
    Dan Fassnacht replied 13 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 15, 2012 at 2:55 am
    Spline Dynamics tag priority can be set directly in the tag’s Basic tab but Dynamics is fixed to Generators/400 internally, you set Spline Dynamics priority higher or lower than the Dynamics priority to get what you want. What are you trying to do?
  • Dan Fassnacht
    December 20, 2012 at 9:43 pm
    Hi Brian,
    Basically I’m connecting a spline with a spline dynamics and constrain tag to a dynamic object. So in this case a cord that attaches to a microphone. The cord tends to lag a little bit after the dynamics of the microphone. So basically I’m trying to mess with the priorities to see if I can get the spline dynamics to be in sync with the rigid body.
    Any info you can provide would be great.
    Best,
    Dan
