Activity Forums Maxon Cinema 4D Priority problem ?
  • Priority problem ?
    Posted by Mikael Aronsson on August 25, 2020 at 4:34 pm
    Hi!
    I have a rig where there is a head joint, this head joint has two child bones that are used for a polygon pony tail hair mesh.
    I control the head joint using a PSR constraint (another rigs rotation is used) and I also have an IK tag on the head that ends with the second ponytail joint, I enable dynamics on the IK chain.
    Problem, I can only get one of them to work, when the dynamics work with the hair joints the head no longer follows the constraint object, or if I mess around with priorities the constraint on the head joint works, the dynamics no longer works.
    Any idea what I am doing wrong here ?
    Mikael Aronsson replied 6 years ago 1 Member · 0 Replies
  • 0 Replies
