Activity › Forums › Apple Final Cut Pro Legacy › printing to video
printing to video
Posted by Peter Brusikiewicz on June 11, 2006 at 1:02 amhey,
for some reason i cannot print to video. I have a sony mini dv dcr-pc110 hooked up to my power book through firewire and i am trying to print a sequence to mini dv but for some reason my camera wont pick up the project. I have pl;ayed around with the video/audio settings, but nothing seems to work. i dont know what else i should tell you but i was wondering as to what i should do and if anyone could give me some guidelines it would be greatly appreciated.cheers
Peter Brusikiewicz replied 20 years, 3 months ago 2 Members · 2 Replies -
Rob Forsythe
June 11, 2006 at 2:02 amThis list contains virtually everything to try to enable:
a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
b. Viewing in the Canvas window on the computer screen.
c. Being able to record on the external FW DV deck or camcorder.
d. Being able to capture from a FW device.If working this list doesn’t cure the problem… you may have a serious PROBLEM!
Try things in this order until you find the “cure”:
1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
2. Make sure you have View (Menu) > External Video> All Frames set.
(If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
10. Make sure you have chosen FW output for A/V:
Final Cut Pro (menu) > Audio/Video Settings… >
Video Playback: Apple FireWire NTSC (720 x480)
Audio Playback: FireWire DV
11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
15. Important: Quit FCP, then Restart FCP.
16. Now again, make sure you have View > External Video > ALL FRAMES set…If it still does not work. “Trash” the FCP Preferences on the Mac
https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html“FCP Rescue” is a free Apple Script that will Trash the Preferences.
It will also restore your user settings afterwards.
Download:
https://www.macupdate.com/info.php/id/14729>Then, start again at my “step 1” above.
And, you should always MIXDOWN your audio before you play your sequence.
First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:Sequence Menu > Render Only > Mixdown.
This can help with all kinds of “sticking” playback problems, audio and/or video.
Peter Brusikiewicz
June 13, 2006 at 9:58 pmthank you very much! you have been a great help, I have found the problem. the main problem was that under VIEW and EXTERNAL VIDEO i had it on off. im sorry to bug you again but now it appears to be a problem with the camera i think and i dont know ifyou would know much about that but the problem is that now, the footage shows up on my lcd monitor on my sony DCR-PC110 camera when i have it in vcr mode but when i want to print to video and i hit the record button on my camera, it records to the memory of the camera, and when i put it into camera mode, the footage does not appear and nothing records but the lens cap, i went througkh all of the camera settings but nothing seems to work, and i never had this problem with this camera, any suggestions??
cheers
