Activity › Forums › VEGAS Pro › Printing to Tape via ADVC 100 Problem
  • Printing to Tape via ADVC 100 Problem
    Posted by Karl Reith on March 31, 2011 at 11:33 am
    I’m new to this support forum thing, so hopefully someone can help me with my problem.
    It seems like a simple thing, I’ve only recently started to edit on vegas (+/- 8 months) and there’s something which I haven’t been able to figure out; as far as I can see, vegas won’t let you import entire folders of media (e.g. a folder of images) by the “drag-and-drop” method. It comes up with an error message saying:
    “None of the files drop on Vegas Pro could be opened.”
    Is there a way to import by “drag-and-drop” method or am I hoping for too much? Alternatively is there another way to import entire folders into vegas with the folder names being retained?
    Karl Reith replied 15 years, 6 months ago 2 Members · 2 Replies
  • John Rofrano
    March 31, 2011 at 4:57 pm
    [Karl Reith] “Is there a way to import by “drag-and-drop” method or am I hoping for too much?”
    You would have to select all the files in the folder (Ctrl+A) and drag and drop all of the files.
    [Karl Reith] “Alternatively is there another way to import entire folders into vegas with the folder names being retained?”
    Not natively, but we (VASST) make a plug-in called Ultimate S Pro that has the ability to import and entire folder structure into the Vegas Pro media bins, creating bin names for each folder and placing the media in the appropriate bins. There is a 15-day free trial to see if you like it.
    BTW, why is your subject: “Printing to Tape via ADVC 100 Problem”?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Karl Reith
    April 1, 2011 at 8:40 am
    Thanks for the reply John,
    Apologies for the title of the post, I had another issue that I wanted to ask but i’m still busy trying find a solution, it’s a long story!
    [John Rofrano] “Not natively, but we (VASST) make a plug-in called Ultimate S Pro that has the ability to import and entire folder structure into the Vegas Pro media bins, creating bin names for each folder and placing the media in the appropriate bins. There is a 15-day free trial to see if you like it.”
    AH awesome stuff, i will definitely give it a try, it’ll most certainly make my workflow a lot smoother!!
    Once again this forum has helped me BIG TIME!!!! (Been reading various other posts for problems that I encounter from time to time). Thanks again!!
