Activity › Forums › Apple Final Cut Pro Legacy › printing anamorphic timeline to DV problem ..
Posted by Mark Pommett on March 9, 2008 at 7:31 pmIm trying to print to video a 16×9 anamorphic timeline onto my PD-150 camera and it keeps coming out letterboxed. Is their a solution?
Thanks.
Tom Wolsky replied 18 years, 6 months ago 3 Members · 5 Replies -
Jerry Hofmann
March 9, 2008 at 8:14 pmI’d *guess* that you need to tell the camera to not letterbox, but to record an anamorphic image… If it’s anamorphic in FCP, the camera should be able to record it as such.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Mark Pommett
March 9, 2008 at 9:54 pmCould I export a 16×9 QT and then bring that file to a dub house and have them lay it to tape anamorphic?
Mark Pommett
March 9, 2008 at 10:09 pmHey Jerry,
I think I figured it out. I took my 16×9 timeline, exported it to Qt with the anamorphic checkbox ticked, reimported into a 4:3 timeline and unchecked the anaormphic box and now it looks squeezed like it should. Is that correct?
Mark -
Jerry Hofmann
March 9, 2008 at 11:14 pmSeems to me you should check that camera’s setup… but if you record a stretched and tall version, and it fills the screen on the DV tape, you’re home free. It’s anamorphic.
Jerry
Tom Wolsky
March 10, 2008 at 12:06 amNo. It should not looked squeezed in the camera viewscreen. Are you sure your original 16:9 material was edited in an anamorphic sequence? Check its item properties. When you output to tape, the material should look widescreen, not squeezed in the camera. Does that camera have a widescreen viewer or is it 4:3? If it’s 4:3 the anamorphic material will be displayed in letterbox. When you shoot with the camera, isn’t that how you see it?
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
