Activity Forums DVD Authoring Printable Files on DVD
  • Printable Files on DVD
    Posted by Colin Wiencek on May 14, 2009 at 3:53 am
    So my client wants viewers to be able to open up the DVD on their computer, as a data disk, and be able to open a set of PDF files and be able to print them. What I did was burn the DVD with the Audio_TS and Video_TS folders and then add another folder for the PDFs. When I do this the DVD will not play. Does anyone know why this is and what I could do to fix it?
    -Colin Wiencek
    Michael Sacci replied 17 years, 4 months ago 2 Members · 5 Replies
  • Michael Sacci
    May 14, 2009 at 4:21 am
    How did you burn the disc, all DVDs are data disc, they need to be UDF.
    You can have DVDSP add this content for you. Put the folder you want on the disc in another folder, then choose that top folder as the DVD-ROM, DVDSP then adds everything in it, in your case the folder with PDFs on the disc. Should then play fine.
  • Colin Wiencek
    May 14, 2009 at 2:19 pm
    Could you give som emore detail on how to do this? I am new to the advanced functions of dvdsp. thanks. -Colin
  • Michael Sacci
    May 14, 2009 at 7:03 pm
    The manual explains how to do this. Don’t be afraid of it, it can give you the fastest answers to most of your questions.
  • Colin Wiencek
    May 14, 2009 at 10:28 pm
    Where in the manual should I look? Not sure exactly what this is called.
  • Michael Sacci
    May 14, 2009 at 10:56 pm
    You are looking for info on “DVD-ROM”
