Activity Forums Apple Final Cut Pro Legacy Print to Video…help?
  • Print to Video…help?
    Posted by Chris Balogh on February 11, 2009 at 4:59 pm
    I am exporting a sequence from print to video. It is exporting out to a set top. Everything is fine until I push ok for the playback….the dv set top even records when I push okay…it is totally black when it is exporting and when I rewind the tape to see if anything printed to video? Why???????
    Stuart Christensen replied 17 years, 6 months ago 2 Members · 1 Reply
  • Stuart Christensen
    February 12, 2009 at 1:00 am
    Hello Chris! Although your question is not really clear, I will tell you what I’ve experienced with this same issue. First, in the dialogue box that pops up when you choose “print to video” Look for a small box to check called “Start recording immediately” and make sure it is checked. If it’s not checked you will experience the black screen/tape issue. Just a guess, Good Luck! STU
    I know alot….but not as much as the other guy.
